I am getting the following error code in VCDS for the temperature sensor:
Does anyone know where exactly the temperature sensor is so that I can check the wiring to/from it please?
00779 - Outside Air Temperature Sensor (G17): Open or Short to Plus
Possible Symptoms
In the Instrument Cluster you see dashes (---) instead of a temperature
Possible Causes
Wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster: Open or Short Circuit
Possible Solutions
Check wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster
Check Measuring Block Value
Possible Symptoms
Possible Causes
Possible Solutions
