1.2 MAP Sensor, Where is it ?
shep0706
243
Darlington
Okay so my car has been running like a dog and i scanned it tonight and it brought up;
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-10 - - - Intermittent
So was just wondering where it was to maybe give it a clean or get the part number of it and get a new one.
Any help appreciated :)
shep0706
243
Darlington
Found it and cleaned it and now i get the codes
16556 - Fuel Trim: System Too Rich: Bank 1
P0172 - 35-10 - - - Intermittent
17658 - Fuel Level too Low
P1250 - 35-00 - -
Could the jerking and the car wanting to stall be due to a blocked filter ? i run my car on the red line then fill up ussualy that could of brought all the crap into the filter and partially bloking the filter ?
Jordanwaterhous
Motorsport > Scene
Sep 15, 2009
1,936
Leeds
www.facebook.com
P1250 - 35-00 - -
That code about fuel level too low just means you're run super low on fuel. GF's polo had it after she'd nearly run out of juice!
Could also be what you said, low fuel dragging all the crud and sludge through.
Get a new fuel filter for it! OR you could check yours, its on the drivers side between fuel tank and sill.
shep0706
243
Darlington
That's the thing the fuel level wasn't that low it was just after the light coming on I've scanned the car on the red line and its never brought that code up before :S
Also do this rule out timing issues ?
I also did the coil pack trick pulling one out at a time and every one of them reacted the same way and mannaged to keep the engine going.
The car does sound alot more vocal when giving it more than half throttle.
Car has got me baffled :blink:
Jordanwaterhous
Motorsport > Scene
Sep 15, 2009
1,936
Leeds
www.facebook.com
I'd replace the coilpacks if I were you, get genuine thought because reps just break each other I.e replace cyl1 and cyl 2 will pop etc.
Sent from my BlackBerry 9800 using Tapatalk
shep0706
243
Darlington
Yeah :) i got the MAP sensor fault code back up now, so ive ordered another one if that doesn't sort it out then its new coil packs and plugs and fuel filter :)
shep0706
243
Darlington
Okay so before i changed the coil packs i was getting a fault code for cyliner 3 missfiring but aafter chaning them i got this
VAG-COM Version: Release 311.2-N
Control Module Part Number: 03E 906 033 D
Component and/or Version: 1,2l/4V SIMOS3 G00HS4342
Software Coding: 00061
Work Shop Code: WSC 06402
Additional Info: VSSZZZ6LZ2R043973 SEZ7Z0B1577440
6 Faults Found:
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
P1250 - 35-00 - -
SWANSWAY CUPRA Dealership
