1.2 tdi dump valve
AdamReynolds
Basically I want to put a dump valve on my car. Does anyone know how to do this on the 1.2 tdi engine?
lawrieIbizaMk4
Team Boc!
Aug 31, 2009
3,541
Milngavie, Glasgow
www.bebo.com
Omg forge make an item that will actually make u lose power hahahahahahahahahaha
...not exactly. Iirc it takes a small amount of compressed air from the intercooler pipes stores it and releases it when the throttle is released from full throttle position much like the "speaker" dump valves which do th same but have a tweeter mounted that makes the noise
AdamReynolds
Fair does. Just wanted that bit of noise that comes from a dump valve. I'm not bothered about speed or performance, I have a 1.2 tdi so that's enough for me. So why can't you put a dump valve on a tdi?
Marty.H
67
Norfolk
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
Lol, seriously man, don't even think of fitting a dump valve on a 1.2tdi even if it was possible, that's just wrong :D
There's another thread on here somewhere with more info, someone asked the exact same question but they had a tdi with poke.
lawrieIbizaMk4
Team Boc!
Aug 31, 2009
3,541
Milngavie, Glasgow
www.bebo.com
It was me. I researched a bit and it looked expensive and would make me look like an idiot at the end of the day so never bothered
Mar 3, 2012
2,090
southampton, UK
Iv heard them on youtybe and thry sound odd. Not my cup of tea. Don't cheapen your motor with crap. Use the money and get a remap :)
Sent from my LG-P920 using Tapatalk 2
MJ
5,551
33
Manchester
Open cone often leads to heat soak - stick with the standard filter as its been proven time and time again that this is all a diesel requires unless you're running daft power.
The item that you'd fit to the diesel engine is called a "blow off valve" not a dump valve, doesnt matter if its fitted to a diesel or petrol it works in the same manner in that it "dumps" excess boost pressure to atmosphere which apparently prevents the turbo over spinning during gear change, its yet to be utilised by any major names which makes me doubt its credibility but its a nice thought and some people enjoy the noise.
