nokiauk
524
25
Edinburgh
Just turned over 3500 miles in my 1.2 TSI and yellow oil light came on, which I was a bit surprised at. I've driven many marques (petrol & diesel) incl. VAG for approx. 20 years and never had to change oil between services.
Anyway I'm still confused the book mentions all the QI codes which I can't find in any manual.
The dealer has crossed the box for fixed servicing so I topped up with the VW 502 00 oil and the light has now gone off.
Would my car have came delivered for Variable or Fixed has the dealer really changed this to fixed for sure.
Hate to think I've used the wrong oil but would normally service every year anyway.
If you are on fixed service intervals 502.00 oil will be perfect.
A top up is not an oil change, its normal for some cars to use a little as they bed in.
But you should check your oil every few weeks and top up as necessary. That is what the dipstick is for, likewise check your tyre pressures and water levels etc.
The idiot lights on the dash are a final warning, when an oil light comes on its normally too late, lets hope for your sake you are lucky.
Spoke to a mate who's a VAG tech, he says the warning lights are 2 stage, yellow (warning) and red (oops).
Only drove 1 mine when light was on anyway as was on way home, I usually do check every month and was ok in October which was when last checked.
Spoke to dealer who has advised that the car will be set to fixed servicing as they change the cars even though factory is set to variable servicing.
Also checked the car computer and it says next oil service due in 165 days which will take the car to exactly 1 year old.
Now to obtain a spare 502 00 to prevent the light coming on again.
I need to top mine up as it is starting to look a little low on the dipstick. Was trying to figure out which service plan it is set to, judging by the media unit I'm assuming variable. Looked in the manual and it says to use 504 for fixed or variable (502 is the first option for fixed). Only problem seems to be trying to source 504 oil!
Sent from my Z10 using Tapatalk
502 00 oil is 0w/30 grade
504 00 oil is 5w/30 grade
SEAT recommend Castrol so you could purchase 5w30 FST or 0w/30FST from any good motor factors that supply Castrol oils
Thanks, I thought as much. I looked a few 5w-30 and they all stated 502, not 504.
I have some Magnatec 5w-30 left over from when I owned my Fiesta, but it says nothing about VW or VW specs on the label, all too confusing!
Castrol Edge 0W-30 meets the VW 502 00 spec.
I use Castrol Edge 5W-30 in my 1.8TSi, £12 for a litre bottle from Asda. Asda don't seem to stock the 0W-30 stuff though. :(
Just checked the Owner's handbook, petrol engines can use VW 504 00. Castrol Edge 5W-30 meets both the VW 504 00 and VW 507 00 specs so you should be OK with this in your 1.2.
