1.4 S Ideas?
ibizamk3
Hi I've just bought myself a SEAT Ibiza 1.4 S and have a few questions:
Is there an easy way to fit an aftermarket headunit?​
Can you fit a standard backbox as the exhaust tip is bent downwards so theres no hole in the back bumper?​
Good rim and bodykit ideas would be much appreciated :)
Thanks in advance.
antnee
Hi and welcome
There is no easy way of fitting a differenthead unit, but it can be done.
The tip is bent downwards on them as standard I think, you could look at getting an aftermarket back box if you want an exhaust tip showing
Bodykit wise there isn't much available, if you do want to change anything, look at getting a cupra kit. Wheels wise, what colour car do you have? You should also think about lowering it too
Mat
body kit is a no no! if you want a bodykit, i suggest join local/national cruise site
the 1.4 is slow enough as it is, so dont add extra weight to slow it down more! i could tell the difference with passengers in the back lol
Dan1.6
1.6 Power FTW!!!!!!!!
Sep 26, 2008
981
Chesterfield
passangers are a big no no you won't get anywere with them in to change a the headunit there is a link on here somewere that does show you that you can cut out/ modify the heater grills to fit a head unit in
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
3 main places for headunit are..
under steering wheel - if you have a remote control
modify current stereo to fit a new one
air vents above current stereo
i've done the last one
