1.6 ecomotive stop start
Jordan93
Hi guys
I've picked up a 2010 1.6 ecomotive
And I'll be dammed if I can get the stop start to work...
Engine is warm Heaters the lot are off
The only way I can get it to work is by stalling it
I've read the manual over and over!
HELP!
Rusty2k
710
133
Do you have a fault code reader or know someone with one? If there's something wrong with the start / stop system there will be fault codes registering that would point you in the right direction.
A common cause is a replacement battery though. They sometimes need coding in before the start / stop system will recognise it as a supported type of battery.
