How do you know when it's regenerating?
The engine holds 1000rpm tickover even when warm and the tickover feels more uneven than normal.
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Thanks. So there's no way of knowing if it's regenerating when driving at 2k rpm on the motorway?
Nope
This is what frustrates most of us - you do a nice long trip only to find when you pull up at the end of it, that the car is doing a regen and needs to be driven further !!!!
We would all like a light or symbol in the dash that says it is doing a regen so we can adjust our route to finish it.
A light would be useful! Is there anything accessible to monitor in the engine bay? Position of EGR valve?
1.4TDi idle is rough anyway, so must be difficult to detect additional roughness.
1 Fault Found:
7563 - EGR Sensor 1
P046C 00 [101] - Implausible Signal
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Readiness: 0000 0000
78k get about 40mpg. had a couple of breakdowns plus new clutch,clutch slave cylinder,gear box, 2 EGR valves, DPF clean and sensor, 2 wheel bearings, radiator, stereo, passenger seat back,other sensors i cant remember, its always at seat!!
getting the ibiza fr 2.0tdi in march tho![]()
Looks like I spoke too soon.
Car went into limp mode this evening coming home from work with the glow plug light flashing.
Scanned it with VCDS and got the following
Seems to be fine now, so I've cleared the fault and will just wait and see what happens tomorrow.
Odd that the recorded mileage for the fault is 0
Shes totally fooked! Engine Management Light is permanent on, glow plug light starts flashing when the power is lost, ignition off and on again clears it for a while.
Will be getting her looked at tomorrow.
I would feel embarrassed driving a Spark. At least they can do the work quickly, hope they've diagnosed the correct part first time.
Other than limp mode and dash lights, did your car experience any other symptoms?
Don't think I'll be keeping the Ibiza long after its out of warranty. This has kinda knocked my confidence in it, and although it's the first problem I've had, im not surprised that its been exhaust related. I don't think modern diesels are worth the risk with all their DPF filters and sensors. My mileage has decreased a lot due to a new job, so i think i'd be looking at petrol in the future!
Please tell me you were doing 55mph all the way else I'll cry!ive just made 2 trips to yorkshire and back which has taken me 2 nearly 3 hours each time and the car has been bloody fantastic the most i had going up the m1 was about 63.2mpg
I'm not stupid enough to tempt fate!I'm of the same opinion Mark, I've not had a single issue with mine in nearly 40,000 miles but I am just a little nervous about keeping it beyond the warranty period.
What to replace it with is the BIG question?
Yes the Spark is a terrible car, but they're a combined Chevy/SEAT dealer and I guess it's cheaper for them to run a fleet of Sparks as courtesy cars, kinda glad too, if they'd gave me a Leon or Exeo lol I'd probably have traded the Ibiza in for one!!!
No other symptoms other than the warning lights and limp mode. Occasionally I thought there was a slight burning smell, but maybe the car was trying to do a DPF regen or something at the same time.
