Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
My 2007 1.4 has two cats.... not sure if yours would be the same or not.
No it doesn't.
Only 1 cat on any MK4 from the factory.
The AA guy plugged it in and came out with fault code po420 ? then said it was the cat. I am going to get lambda sensor first as it makes sense to check that before just changing the cat.
No it doesn't.
No it doesn't.
I am 100% sure mine has two as I have a small hole near one of them which can't be welded. I have been quoted £500 for a replacement exhaust system as it has 2 cats.
