plebmaster
I have bought a can of 10k boost for my LC, and the only instructions on the side state:
'Apply 10k boost directly into the turbo charger inlet'
Could someone please point out the exact location of this, as I dont want to buggar the car up - and I'll be damned if I can find a diagram of the engine anywhere!
Many Thanks,
Luke
YerMother said:
10K Boost what the hell is that and what does it do?
Guess its a de-coker of some kind, the car has 70k on the clock, so could do with some tlc! Have had friends use it, and swear by it - so for £20 I think its worth a shot!
YerMother said:
Just follow the big pipe coming out of your airbox down behind the engine! That connects to the inlet of the compressor!
Excellent - thanks for that (thought it sounded easier than I thought!)
Not the sort of thing i'd be tempted to use anywhere near the MAF though.
You need to be running the engine while you spray it in, i'd unplug the MAF and whip it out of the way; you'll need to be able to clear the fault code that is generated from doing this.
