12volt cigarette power rating?
rob1
IBIZA TDI CUPRA
Sep 14, 2004
189
WALES
I've recently bought a 12volt heater and it states that it pulls 13amp of power and I was wondering what the current limit is with the cigarette lighter in the ibiza (54plate).
I would have checked my handbook but ive lost it during a recent house move.
Nath.
The Gentlemans Express
Jan 1, 2006
8,617
16
EASTLEIGH, HAMPSHIRE
IIRC it is at least a 20 amp fuse so 13 amp will be more than fine
The lighter ring pulls a fair bit more than 13 amps I reckon
The easy way is to read the book but failing that just plug it in and if it does blow the fuse you just need to go looking for the only blown one in the fuse box, that will be the one in question............
rob1
IBIZA TDI CUPRA
Sep 14, 2004
189
WALES
i was tempted to give it a try until i saw my dads focus with 12v 10amp stamped on the front. im guessing in the fuse box it will be a fuse just for itself and not connected to any other systems power ?
Nath.
Jan 1, 2006
8,617
16
Yeah it will be a fuse for just the lighter, as you have seen any car that has just got a charger or 12 volt outlet normally says on it what sort of amps you can draw. If it doesn't say anything you can draw as much as is required to make a metal coil glow red hot so 18 amps is well under that
CHR15B
2,560
Scotland
got to ask what is wrong with the heating in the car?
There are warmer options...
g8rvn
154
Tamworth, Staffs
the best way to check is to take the fusebox cover off and see what size fuse powers the cigarette lighter, if its rated higher then your heater then theres no problem, if its lower then it will just blow striaght away
