alijay
7
97 Cordoba TDI
Having a problem adjusting the handbrake. New shoes fitted recently and I can't adjust the nearside cable, despite accuating the self adjuster the NS cable is screwed up to the maximum on it's thread and even then the NS wheel can still be rotated albeit with some difficultly when the OS wheel is locked solid with only a small amount of thread showing on the adjuster. Any help will be appreciated. I've followed the adjusting guidance to the letter.
take the cables off and check that you can spin the disk. if you cant then the caliper may of seized they have a habit of doing that.
