1998 arosa/ibiza engine
chewiee
hello, just wondering, would it be possible to drop a 1998 seat ibiza engine straight into an arosa or are they completely different?
chewiee
i'm looking at buying an arosa with a burnt out mpi1.0 engine and dropping an mpi 1.4 from an ibiza into it...
Seatmann
Rough around the edges
Sep 16, 2010
5,568
9
Scotlanda
If they do a 1.4 Arosa then it should at least fit but you'll probably need to tweak things to get it to run properly.
st3rg
if it has AER 1.0 engine you should go for a 1.6 AEE engine + ecu its a straight fit.
ianswebb
My arosa is a 1.4 apq.. i believe the apq was also used in the vw polo. Might give you a few more options.
Ian
