illzlee
hey everybody, i'm in need of some help - first post and i'm already desperate!
my 99 2.0 16v cordoba is overfueling like mad, only on startup? it's fine when warm but will not start 75% of the time.
now before you suggest stuff, please have a look at what i've done so far!
new coolant temp sensor fitted
new coolant temp sender fitted
new leads fitted
new dizzy cap /rotor arm fitted
new plugs fitted
ecu removed and checked by specialists - no problem (even tested underwater!)
injectors removed & tested - no problem
replacement coil pack fitted - made no difference
countless diagnostics performed - no codes stored
fuel pressure regulator tested - no problem
and the best one.....
one of the dogs dangliest diagnostic jobbies in derby connected to the car (when it won't start) - no problem!
it has 3 AA men stumped, my local garage stumped & the diagnostics place willing not to charge just tell them what the problem is!
there are several similar problems on here, but i seem to have tried everything but a crank sensor.....thats next but at 150 quid it's a last ditch effort before i hand it over to gk seat in derby along with my credit card and say
"fix it regardless of cost or scrap the fcuker"
last chance here folks, please help!
new leads fitted
new plugs fitted
