ibiza_mero_2010
i have this ibiza and i have abf engine with kr ported and polished head with abf cams
i have 2 proplems
1st i broked 2 gearbox and now i have aug gearbox but its too slow in all gears i need gearbox give me big torque in 1st and 2nd gears and in the same time give me topspeed and can Bear the strength from that engine what code can i use ....
2nd proplem
i need to know the compression ratios in my engine with this head and this head will give me more hp and trq or will make me loss some .
i hope some one help me​
but the abf box is too weak in the 1 and 2 gear .. coz it clutch work with oil and the top speed not to far i need more
the Pedal work by oil press not with wire and i mean Weak in the 1st and 2nd gear or that box fast after the 100 km\h
i think about the 4t g.box the ratios is f.d 3.89 1st 3.45 2nd 1.94 3rd 1.29 4th .91 5th .71 i hope it can Bear the strength coz it was in 1.6 and 1.8 engine what do u think about it
The correct ABF gearbox is a 02A with ratios CDA and this gearbox is cable not hydraulic (oil).
i think i can use the 4t GEARBOX what do u think about it !
Don't know what the 4T is from?? The 02A box is very strong, like Ben said 300+bhp is easily handled!
Or if you have some money bit aside source a ex VW Cup car dog box like mine lol.
if the 4T box is out of the 1.6 8v and the 1.8 8v like the mk2 golfs then its not a good box at all... its rod shift and like chocolate... if its not the mk2 golf box then i have no idea what it is either :D
02A you can stick a longer final drive in if you want for optimum motorway driving, but youll really only get a better 5th gear without messing about with all the ratios
02A I SEE ALL OF YOU LIKE THIS .... SO WHICH exactly code in the 02a will be gr8 in the 1st and 2nd gear and give me top speed . ! cha or ayk or agc . or which one ! thx ibiza_95 and dave_r for your help
