Hi can any one recommend a good air filter / induction kit for my fr 2.0 tdi 170 not sure weather a better panel filter or cone filter is best thanks
i have the Neuspeed p-flow on my 2.0 170 and it seems to have better throttle response from the original enclosed box, power wise i couldn't honestly tell, i would go back to standard but i love the sound the p-flow makes.
Can u make a video of the sound please mate?
I'm looking to book mine in for dpf and egr delete and remap next week. Still undecided on stage 1 or 2 thowot u going for?
If you go for stage 1 in a few weeks you will regret your decision ...
So if I ask sharks for stage 2 (218) then ask them to take it back a little is that possible or is it non adjustable?
yes limit boost to around 25psi and ther should be no stuter but for some unexplained resson some cars are worse than others
you wont get any stuter tho and if you do it should be fixed for free
I have tried to explai this to tuner which I used but he said that all limits are increased and 26psi should be no longer a problem but I still experience some stuttering and is bit more than occasional ... is not that bad to be honest and is always in 3rd gear .
you can raise all the limits to 5000 mbar from 2700mbar and the stuter will still happen
the way shark get round the stuter is they make the map progressive so ther is no massive spike of boost
this means you can get max boost and also keep boost under strict controll and get it rite against the boost stuter limit
Is there a lot of alternation to map required to make it more progressive as now I can feel massive boost and than is just cut off twice somemetimes three times when boost hit limiter like you say 26psi ...
Is this just some kind of protection for turbocharger ? can this be taken off from ECU?
