Yup otherwise I wouldv made myself look like a real tart :D
Boost gauges rock the party! Tells you pretty much imediately when something is wrong. My software was reset by battery being disconnected during exhaust repair. The gauge showed 17psi instead of the regular 24psi and voila problem highlighted.
@hubbly_bubbly
my friend could you help me to find an air vent mount for gauge like yours???
do you have any links from any site???
Thank you!
Hi thanassis :)
I actually designed and made the bezels for the vent mount gauge myself. I have a design for 45mm and 52mm now. PM me your email addy and ill send them to you. I had them made out of black gloss plastic (perspex i think) by a local plastic supply company who profiled the bezels for around 25 pounds.
Hi thanassis :)
Thank you for you respond!!! but I cannot send you pm, maybe because I am a new member..
my mail is the username with a "k" in front of it, at gmail.com
does the vent work after the retrofit you have done???
Will send you the profiles tomorrow.
The vent does still work 100%. There are slots in the bezels that allow the air to flow through. There is however no direction control of the flow but for the 1.5yrs i have had the gauge i neva really missed the direction control of the air.
45mm AWE vent mount boost gauge.
Standard boost just under 15psi (14.7psi =1bar). Stage 2 revo 24psi peak boost from the K04 in a Cupra.
Hi mate where did you buy this from and how much?
Also how was fitting for it?
Thanks.
JubeTigeruk
