Masterkm
My Leon 'Alyssa'
Jul 11, 2011
2,700
Halesowen, West Mids
After scanning with VAGCOM the following came up:
2 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10): Open Circuit
P161A - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 120764 km
Time Indication: 0
Date: 2000.00.00
Time: 21:26:19
Freeze Frame:
RPM: 1071 /min
Speed: 1.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00101100
Temperature: 15.3°C
Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
P161B - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 120764 km
Time Indication: 0
Date: 2000.00.00
Time: 21:26:19
Freeze Frame:
RPM: 1071 /min
Speed: 1.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00101100
Temperature: 15.3°C
Bin. Bits: 10110000
So I am thinking is this the reason why my MPG is lower than expected at around 48mpg or am I just talking bull**** lol
I have got a full set of new glowplugs from Dave and as I am changing these 2, I might aswell change them as a set.
Would this sort out my problem regards to the above VCDS codes? Car is running ok btw, nothing bad that has come to my attention since having it.
Thanks guys
Sorry for daft question, what made you scan with vag com, are the glow plugs hard to fit, think I have same as you (1.9tdi)
Sent from my GT-I9300 using Tapatalk 2
Nothing really mate, I just had a VAGCOM kit delivered so thought might aswell test it out. Codes showed up so decided new plugs should fix it lol.. All plugs were changed in around 10mins by my dad just need a rachet kit.
