Cpn
Sep 21, 2021
Hello,
I have a 2007 Leon Cupra which is showing the following fault:
p2279 code- intake air system leak, lower limit exceeded.
The symptoms are that the car runs rough at idle and the rpm rises to 1200-1300 in neutral periodically before settling down. The strange thing is that this only happens when the car has been driven for a few mins and is warm.
I had a similar issue on another Cupra which turned out to be the pcv valve. I replaced the valve but no joy.
the car is standard apart from a Milltek non res cat back and remap.
any info would be much appreciated as it is a pain in the backside.
thanks
Is your dip stick in properly? And your oil cap? You’ve definitely got a air leak so you’d need to look at it while the car is running you might even be able to hear it sucking in air while running.
Reactions: Cpn
Thanks for the reply. It’s a strange one. It only seems to happen once the car is up to temperature. I’ve checked all the obvious weak points. Next stop the mechanic…
