Jul 1, 2026
Right excuse me for the time , I work nights..
replacing many parts on a Leon 184 after scanning a p2102 code, I can tell you the problem..
Symptoms… If your car is not in limp it will sound alot more ‘whistle’ and won’t pull mid range…
The part that needs replacing is the throttle valve
9 times out of 10 it will be ok after cleaning the part and removing the codes ..
but for the sake of an extra £130 off febi, you should replace the whole assembly!!!
Hope this helps , as it’s a a very common issue and has not been answered properly!!
