2010 Ibiza Boot Lock Mechanism removal
Aug 8, 2020
I need to replace the boot lock mechanism, but the bolts attaching the mechanism to the lid are a type I do not recognize (see attached photo). I read in one of the posts that said it is a 10mm multi spine - any ideas where I can purchase the item required?
RUM4MO
7,821
997
South Scotland
If you need to remove and fit that bolt you will need to buy a kit that has Spline bits, easy to do, my main bit kit has Spline, Hex and Torx, for Rib I needed to buy another kit.
Aug 8, 2020
Thanks - I bought a multi-spline set for £11.99 from eBay, that plus the £14.99 for the lock mechanism and it is all fixed and working fine for a fraction of the price it would have cost if I had gone to the garage - thanks again for the info.:)
