While driving? He'll probably end up with more than sound to worry about.
This wins dumbest suggestion of the month.
Maybe he meant to take a passenger to set it while he was drivingWhile driving? He'll probably end up with more than sound to worry about.
Not as harsh as killing someone while f**king around trying to adjust virtual sliders on a screen in the middle of the dash. It's not the same as pushing buttons on your steering wheel.That’s a touch harsh. Surely we all adjust stuff when we are driving? You could always pull over to make adjustments and then carry on or get a passenger to do it if you wanted to be extra careful. No harder than searching for a radio station, entering a sat nav destination or having an argument with your missus
I had the new 2018 Ibiza before I went to my MK3 Leon Cupra, although the sound is louder the quality isn’t quite as good. And in the Ibiza it had the actual values “bass” “treble” etc... which was much more helpful. But I usually use my engine/ exhaust note as my music so no need for speakersSo far ive found the system a little flat. Its more clear than my Astra, but doesn't have the bass. Interestingly my equaliser was set to maximum on all bands when it arrived, usually equalisers are set to the middle on all bands by default. Not sure if the delivery guy had adjusted it or not though. Reducing the mids has helped.
At least there are no rattles at higher volumes.
I find the driver focus works best for me!Another thing is the focus of the sound in the car. I found if you select sound focus on “driver” rather than “all” it *could* sound better. But it wasn’t clear enough a difference for me to leave it like it. But maybe your ears will hear it differently.
Yep, but only if you have an afro and pink disco glasses.All this talk about Bass, Beats, B&O, Watts, MHz, - will it play my 8 track cartridges?![]()
