Hi, the
problem got worse and started jumping at about 40mph and then going into limp mode. I used something called Revive, which is a turbo charger cleaner. this has helped but not totally cleared the
problem. I also changed the vacuum pipes, this made no difference. Also around the same time my cruise control stopped working, I have not managed to find the
problem to this as yet.
In my opinion dealers have no idea what is going on because they only use the computer, if that does not tell them anything they are stuck. If you are competent the above two jobs are pretty easy to do, though the revive is pricey.
I am going to give the revive another go, to see if it completes the job.
