235/45/17 should I get no rubbing in the rear ?
markoh
Empi5
Your scaring me.......
Feb 24, 2005
2,807
Staffordshire
I think you need to provide a little more info chap, ie, What model, what year, any suspension mods etc etc etc
AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
iv got FR wheels, 225/45/17 and its down about 40/45mm and theres no rubbing, also i had a full car last night and the backs were all the way down and there was no rubbing
markoh
I've already got 235/45/17 in the rear. Fits perfectly ;)
225/45/17 in the front
Deleted member 19366
be carefull as the 235/45 tyres on rear could cause prob's in future with abs & tc. as 225/45 & 235/45 have 2 competely different rolling circumferences which is used to set up the abs & tc. normally if you want to go wider on the rear (why on a front wheel drive?) then the rears should be 245/40/17
daveyonthemove
Smile if you like SEAT's
May 14, 2006
1,519
Wrexham
If they fit perfectly how is it that you have scrub?
But people with 225/45/17's don't have scrub?
I'll let you ponder that one for a bit ;)
NickT
429
LB, Beds
I must be getting old, I'm buggered if I can follow this thread!
However I do have a query (apologies for the minor hijack):
According to http://www.toyo.co.uk/tyre_converter.php
225/45R17 are 636dia
235/45R17 are 640dia
245/40R17 are 628dia
I would have thought the 245/40R17, having a bigger difference in dia to the 225/45 and therefore in rolling circ, would be more likely to cause an issue with the abs & tc setup?
I'd just like to point out "I only know wot I read" so apologies if I'm missing the obvious.
basically when a tyre is made they mark it at 1 point let it do a full revolution and then mark it at point 2. this distance is then messured and the cars abs & tc are then set up using this figure. if you stand a 225/45 next to 235/45 not only would there be a 10mm difference in width but there will also be a couple of mm difference in tyre height, this is becomes greater once tyre is fitted and inflated.when changing tyre width on car you should go lower on sidewall size ie: bmw 3 series will have 225/45/17 on front and 245/40/17 on back.
sorry if i've sent everyone to sleep but sat through 50hrs of training with michelin:)
