Nitrac do custom brake discs built to specifications, try pinging them an email or somet... http://www.nitrac.co.uk/
other than getting them made or re-drilled i don't think there's a model out there that uses a 4x100 312mm disc...
The closest I can think of is there are some manufacturers who make discs that have both four and five bolt holes already drilled. I think my last pair of EBC had both four and five?
But apart from that, any car that uses 312mm discs as standard is more likely to have a five bolt wheel.
I believe the 312mm multi fit disks are 5x100 and 5x112? Iirc its the two pcds of the cars that come with 312mm disks. They aren't fitted to anything 4x100 As that's vw's old pattern. everything is 5x100 or more, post 2002 throughout vag. (Started changing over even earlyer. were mk3 golfs not 5 stud?)
I think the largest 4x100 disk is 288mm? (except of course our ibiza brembos at 305mm but they are a bit thicker than most also)
The ones I remember are the 4 stud and 5 stud combined (I'm almost positive it's an EBC thing), although you have quite rightly pointed out that the PCD is also different which would make the ones I'm thinking of completely redundant.
