360 camera view
TÜRKEL
37
14
Kent
The drivers seat is electric, I have tried both 0 & 1 to no avail, went through the link you sent, looks a little different but the gist is the same, only had to confirm that all was the same. However now when the front passenger door is opened the window goes down 2 inches, then on closing the it goes back up?? WTF
Tell
Reckon the micropayment app you first used messed stuff up, I always say dont use them since you don't know what they are doing or how to reverse it. The history option may show what it did but does show what you did. You need to undo back changes informed by the history file... scientific method 😉.
Tell
Yes you go to the bottom of each of the system lists in the history file and that's shows you what it came from.
Passenger door, Central Electronic Control Unit etc. Look at the date, hopefully that tallies. I'd go down the list from now backwards and hopefully the date of when you first ran the app appears on the list.
Make a running note of what changed from now to the start point and get it back to the start point on all the changes in those two systems. Then start again. So menu option should go after you reboot the infotainment screen. Then start again with the memory seat note as per the text.
Suspect the micropayment app ignored that you had the memory seat fitted which is why it didn't work. Do it via the link I gave when things are back to the factory set up with the memory seat wrinkle.
Ps. You can study the history without the dongle plugged in, useful feature.
