Easy to fit but your remap has to be written for it. Running a 4bar FPR on the standard pump will put extra load on the pump, possibly leading to pump failure. Most modern stage 1 and 2 maps don't need 4bar fuel pressure.
Nothing really to be gained here, just means the fuel system has plenty of headroom to cope with what the ECU requests - you won't get any extra power just by fitting one, unless the map needs it and you're running lean. Whoever you get your map from should be able to tell you if theirs needs 4bar of fuel pressure or not - most don't nowadays.
