5 error codes
sargey
Escaped mental patient
Aug 16, 2006
324
Weston-super-crapland
Ok. I have a leon cupra, i reset everything (disconnected the battery) drove it for a couple of days and did a diagnostics check and found the following 5 error codes
17545 P1137 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
17769 P1361 Cyl. 3, ignition circuit Open Circuit
17772 P1364 Cyl. 4 ignition circuit Open Circuit
17705 P1297 Connection turbocharger - throttle valve pressure hose
18010 P1602 Power Supply (B+) Terminal 30 Low Voltage
how do i rectify these problems? and possible prices on parts if applicable? cheers
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
disconnect the battery or reset the error codes then take it for a drive, check it again when you get back, sounds more like a battery has been disconnected or run down a little.
Mitchy
TTRS
Oct 12, 2004
2,310
When you disconnect the battery leave it for around 20mins before connecting it back up. This will clear all your fault codes!
If after 2 days they've all appeared again then it looks like you have a few problems. The18010 code is nothing to worry about, that is a fault code because you have disconnected your battery!
So you have 4 codes to worry about.
1st one looks like it can be MAF/Cat related due to over fuelling
2nd/3rd look identical but looks like it could be coilpacks/sparkplugs?
4th, may be a loose/damaged hose somewhere around the turbo
I would take it to a stealer tbh
sargey
Aug 16, 2006
324
its going in to stealers on the 6th for an oil change, will tell them ive had these problems and get them to check it out
ive changed the plugs and coils. so i might take it to an auto electrician to check over the wiring of all 4 cyclinder ignitions as if ive changed plugs and coils it can only be wiring?!?
I might have a split turbo hose so get them to check it out
As for MAF ive had that changed within past 2 weeks
