Limp mode with multiple fault codes
Feb 4, 2023
Hello all,
I'm new to the forum and wondered if anyone has seen this problem before.
The car is a 2018 150 Leon FR 2.0 diesel.
There are 5 fault codes which are on permanently:
1. Transmission neutral position sensor - implausible signal
2. Sensor reference voltage C - open circuit
3. Sensor for internal pressure of cylinder 3 - electrical error
4. Turbo/supercharger underboost
5 Transmission neutral position sensor - electrical malfunction
The car goes into limp mode randomly, usually within a couple of miles into the journey.
We replaced the #3 glowplug sensor last week. The code for that cleared initially, but is back
The car apparently has a long history of this fault going back three years.
Any help would be much appreciated.
Thanks in advance
Like Reply
Report
Oily Rag
Reply
Report •••
BoldItalicMore options…
Insert linkInsert imageMore options…
UndoMore options…
Preview
Font sizeText colorFont familyListAlignment
  • Align left
  • Align center
  • Align right
  • Justify text
Paragraph formatStrike-throughUnderlineInline spoilerInline code
SmiliesInsert GIFQuoteMediaInsert tableInsert horizontal lineSpoilerCode
RedoToggle BB codeRemove formattingDrafts
Write your reply...
Post reply
Attach files
Similar threads​
[IMG alt="cosgrove999"]https://www.seatcupra.net/forums/data/avatars/s/135/135367.jpg?1665419434[/IMG]
Intermittent limp mode
Chris Bartram
[IMG alt="Hamlet Du Fromage"]https://www.seatcupra.net/forums/data/avatars/s/135/135632.jpg?1668730540[/IMG]
Wiring problems or something more serious?
Hamlet Du Fromage
Stuck in Limp.. lots of errors, cannot regen. ( DPF recently cleaned )
mty12345
Dashboard dead after changing ignition barrel
12
Nov 13, 2022
hashtagawe
[IMG alt="Almeiidaa"]https://www.seatcupra.net/forums/data/avatars/s/134/134154.jpg?1653633917[/IMG]
Problems with my Seat Leon Cupra R 1M
mty12345
Share
Forum software by XenForo® © 2010-2021 XenForo Ltd. | Style and add-ons by ThemeHouse
adam davies
329
135
Like Reply
Report
Oily Rag
Reply
Report •••
UndoMore options…
Preview
  • Align left
  • Align center
  • Align right
  • Justify text
Write your reply...
Post reply
Attach files
Similar threads​
Chris Bartram
Hamlet Du Fromage
mty12345
12
Nov 13, 2022
hashtagawe
mty12345
Share
Is the car dsg or manual. I would possibly try seeing if the neutral position sensor is working correctly using diagnostics vcds or obd eleven. Found this link could be the problem. If the values are move onto one of the otger errors.
Feb 4, 2023
Thanks Adam.
It's a manual but it's also faulting the #3 glow plug, which was replaced last week, and the turbo underboost.
It had the same faults in 2020. Glow plug #3 sensor replaced. Fault continues.
adam davies
329
135
Forgot the link. https://www.google.com/amp/s/www.op...al-gear-sensor-implausible-signal?hs_amp=true.
When you replaced the glow plug and the fault came back that would suggest the glow plug itself is not at fault. Check wiring to glow plugs and compare voltages to working ones. If that checks out you possibly have and internal engine problem.
Also check the link above about neutral position sensor
Thanks Adam.
DTR
Mar 5, 2023
Hi I've got a 15 plate 2.0 tdi leon fr 184, I have the cylinder 3 glow plug fault code, bought a new glow plug and that hasn't come back up but I have a fault p02990 turbo underboost. Car is constantly trying to regen, its on 152k, done a bit of testing swapped n75 valve for a know good one same issue, carried out forced regen and cleared most of the soot, same issue, looking at live data, when flat out its asking for 1300 something, forgot the unit, and the turbo is only giving 900-1000. Bit unsure I believe it could be the actuator, got a vacum pump on order to test everything. Just after a bit of advice. Thanks. Dpf ash mass value is roughly 60 grams so I know the dpf is near the end of its life but just trying to rectify the lack of power first. Engine does rev freely so dpf isn't completely blocked solid.
Feb 4, 2023
Thanks for that. Sounds like you know what you're doing more than I did!
Luckily for us, the dealer agreed to swap the car as we'd only had it for 2 months. He's got an UP Gti now.
All the best for your troubleshooting/rectification.
