I'd love to post the actual logs taken from block 005 in the same format as others I've seen on here ie complete with scroll bars to scroll up and down the logs.
If anybody can help me with that then I'll update with the actual logs.
Anyway, out of 5 runs I got 8.15s, 7.24s, 7.86s, 8.16s, 8.14s.
These were taken by accelerating slowly up to 50mph then using 4th gear (6 speed box and no gear changes) stamping on the gas until I broke the 100 barrier.
Vagcom takes 3-4 samples per second so I've taken timestamps as close to 60 and 100mph as possible, going slightly under 60 and over 100 so as not to 'cheat'
The two times in the 7s bracket landed very close to 60 and 100 as you'll see if I manage to post the logs
How accurate is the speed read by vagcom?
EDIT - now put the logs in a webpage - vagcom 60-100 logs
