GaryM
Golf GTI 1.8T 180
Feb 11, 2004
378
Nr Manchester
I'd love to post the actual logs taken from block 005 in the same format as others I've seen on here ie complete with scroll bars to scroll up and down the logs.
If anybody can help me with that then I'll update with the actual logs.
Anyway, out of 5 runs I got 8.15s, 7.24s, 7.86s, 8.16s, 8.14s.
These were taken by accelerating slowly up to 50mph then using 4th gear (6 speed box and no gear changes) stamping on the gas until I broke the 100 barrier.
Vagcom takes 3-4 samples per second so I've taken timestamps as close to 60 and 100mph as possible, going slightly under 60 and over 100 so as not to 'cheat' :p
The two times in the 7s bracket landed very close to 60 and 100 as you'll see if I manage to post the logs :rolleyes:
How accurate is the speed read by vagcom?
EDIT - now put the logs in a webpage - vagcom 60-100 logs
The the speedo is an analog device, not much precision there.
The speed reported by the engine (or other systems) is typically no more than 1-2% off. It should have the same accuracy as your odometer, which you can check on a 10-20 mile stretch of road that has mile markers.
-Uwe-
i think you can select in excel the data you want to put in your message then "copy" and "paste" it in a [ code][ /code] in the message (without the added space) :)
That didn't work, it showed the data but not in a smaller box with scroll bars.
Anyway, I've put the logs in a webpage here - vagcom 60-100 logs
Code:
  	   	 Engine Speed  	 Engine Load  	 Speed  	 Speed
	TIME
60-100
mph 	STAMP 	 /min 	% 	 km/h 	mph
0 	199.41 	4720 	99.2 	95 	59.0
	199.72 	4920 	160.9 	98 	60.9
	200.02 	5080 	175.2 	101 	62.8
	200.32 	5240 	173.7 	105 	65.3
	200.62 	5400 	169.2 	108 	67.1
	200.92 	5560 	166.2 	111 	69.0
	201.23 	5720 	163.9 	114 	70.9
	201.53 	5840 	157.9 	118 	73.3
	201.83 	6000 	156.4 	121 	75.2
	202.13 	6120 	152.6 	123 	76.4
	202.44 	6240 	150.4 	126 	78.3
	202.73 	6400 	148.9 	129 	80.2
	203.05 	6520 	145.1 	131 	81.4
	203.35 	6600 	142.9 	134 	83.3
	203.65 	6720 	141.4 	136 	84.5
	203.95 	6760 	139.8 	139 	86.4
	204.24 	5320 	95.5 	140 	87.0
	204.54 	5400 	133.1 	141 	87.6
	204.84 	5520 	163.2 	143 	88.9
	205.15 	5600 	166.9 	145 	90.1
	205.46 	5640 	162.4 	147 	91.4
	205.76 	5720 	161.7 	149 	92.6
	206.06 	5800 	160.2 	151 	93.8
	206.36 	5880 	159.4 	153 	95.1
	206.65 	5960 	158.6 	155 	96.3
	206.97 	6040 	154.9 	157 	97.6
	207.27 	6120 	154.1 	159 	98.8
8.15 	207.56 	6160 	152.6 	161 	100.1
0 	841.16 	3760 	185 	96 	59.7
	841.46 	3880 	188 	99 	61.5
	841.76 	4040 	191 	103 	64.0
	842.06 	4160 	188.7 	106 	65.9
	842.36 	4280 	188.7 	109 	67.7
	842.67 	4400 	188.7 	113 	70.2
	842.97 	4520 	187.2 	116 	72.1
	843.28 	4640 	187.2 	119 	74.0
	843.57 	4760 	185.7 	122 	75.8
	843.88 	4880 	183.5 	125 	77.7
	844.18 	4960 	182.7 	128 	79.6
	844.47 	5080 	180.5 	131 	81.4
	844.78 	5160 	177.4 	134 	83.3
	845.08 	5280 	174.4 	136 	84.5
	845.38 	5360 	171.4 	139 	86.4
	845.68 	5440 	169.2 	142 	88.3
	845.99 	5560 	166.2 	144 	89.5
	846.28 	5640 	166.2 	146 	90.7
	846.6 	5720 	162.4 	149 	92.6
	846.9 	5800 	163.2 	151 	93.8
	847.19 	5880 	160.9 	153 	95.1
	847.5 	5960 	158.6 	155 	96.3
	847.8 	6040 	157.1 	157 	97.6
	848.09 	6080 	154.1 	159 	98.8
7.24 	848.4 	6160 	153.4 	161 	100.1
0 	42.52 	3720 	185.7 	95 	59.0
	42.82 	3840 	187.2 	98 	60.9
	43.13 	3960 	185.7 	101 	62.8
	43.44 	4080 	187.2 	104 	64.6
	43.74 	4200 	187.2 	107 	66.5
	44.03 	4280 	188 	110 	68.4
	44.33 	4400 	186.5 	113 	70.2
	44.63 	4520 	188 	116 	72.1
	44.94 	4640 	185.7 	119 	74.0
	45.25 	4720 	185 	122 	75.8
	45.54 	4840 	182.7 	125 	77.7
	45.85 	4960 	180.5 	127 	78.9
	46.14 	5040 	178.9 	130 	80.8
	46.44 	5120 	176.7 	133 	82.7
	46.75 	5240 	172.9 	135 	83.9
	47.05 	5320 	172.2 	138 	85.8
	47.35 	5400 	169.2 	140 	87.0
	47.66 	5480 	166.2 	142 	88.3
	47.95 	5560 	164.7 	145 	90.1
	48.26 	5640 	163.9 	147 	91.4
	48.56 	5720 	162.4 	149 	92.6
	48.87 	5800 	160.9 	151 	93.8
	49.16 	5880 	158.6 	153 	95.1
	49.47 	5960 	159.4 	155 	96.3
	49.77 	6040 	154.9 	157 	97.6
	50.08 	6120 	156.4 	159 	98.8
7.86 	50.38 	6160 	154.1 	161 	100.1
0 	251.91 	3560 	191.7 	90 	55.9
	252.21 	3680 	185 	94 	58.4
	252.51 	3840 	187.2 	97 	60.3
	252.82 	3960 	190.2 	100 	62.2
	253.13 	4080 	191 	104 	64.6
	253.42 	4200 	188 	107 	66.5
	253.72 	4320 	190.2 	110 	68.4
	254.02 	4440 	188 	113 	70.2
	254.32 	4520 	186.5 	117 	72.7
	254.64 	4640 	185.7 	120 	74.6
	254.94 	4760 	183.5 	122 	75.8
	255.24 	4880 	182 	125 	77.7
	255.54 	4960 	182.7 	128 	79.6
	255.83 	5040 	180.5 	131 	81.4
	256.13 	5160 	178.2 	133 	82.7
	256.44 	5240 	172.9 	136 	84.5
	256.74 	5320 	172.2 	138 	85.8
	257.04 	5440 	169.9 	141 	87.6
	257.34 	5520 	169.2 	143 	88.9
	257.65 	5600 	167.7 	145 	90.1
	257.95 	5680 	165.4 	147 	91.4
	258.26 	5760 	164.7 	149 	92.6
	258.55 	5800 	164.7 	151 	93.8
	258.85 	5880 	160.9 	153 	95.1
	259.16 	5960 	161.7 	155 	96.3
	259.47 	6040 	157.1 	157 	97.6
	259.77 	6080 	154.9 	159 	98.8
8.16 	260.07 	6160 	155.6 	161 	100.1
0 	515.91 	3800 	187.2 	97 	60.3
	516.21 	3960 	187.2 	100 	62.2
	516.51 	4040 	190.2 	103 	64.0
	516.81 	4160 	187.2 	106 	65.9
	517.13 	4280 	189.5 	109 	67.7
	517.42 	4360 	188.7 	112 	69.6
	517.72 	4480 	188 	115 	71.5
	518.02 	4560 	186.5 	118 	73.3
	518.32 	4720 	185 	121 	75.2
	518.62 	4800 	185 	124 	77.1
	518.93 	4880 	184.2 	126 	78.3
	519.24 	5000 	182.7 	129 	80.2
	519.53 	5080 	179.7 	131 	81.4
	519.83 	5160 	176.7 	134 	83.3
	520.13 	5280 	175.9 	136 	84.5
	520.44 	5320 	173.7 	138 	85.8
	520.74 	5400 	169.9 	141 	87.6
	521.04 	5480 	169.9 	143 	88.9
	521.34 	5560 	166.9 	145 	90.1
	521.64 	5640 	167.7 	147 	91.4
	521.94 	5720 	165.4 	149 	92.6
	522.26 	5800 	163.2 	151 	93.8
	522.56 	5880 	160.9 	153 	95.1
	522.86 	5960 	160.2 	155 	96.3
	523.16 	6000 	159.4 	157 	97.6
	523.45 	6080 	155.6 	159 	98.8
	523.76 	6160 	154.9 	160 	99.4
8.14 	524.05 	6200 	153.4 	162 	100.7
hummm it seems to work, i've copy/paste data on your html page in a code tag, just quote my post if you want to see ;)
:redface:
i have one question, i would have thought using a newer ecu than my ibiza and being in kwp2000 on your golf the turbo button in vag-com was available to take more than 3 samples per second :confused:
Looks like you left your handbrake on looking at those times.:p
I have the KEY-USB interface which isnt compatible with Turbo mode, for that you need the professional HEX-USB interface which was $100 more and not really worth it for me.
Ross-Tech vagcom interfaces
