69mph warning!
furtive
7
9
I've got a 2019 Cupra and if I go faster than 69mph (on private roads, obviously...) I get a warning on the dash and a bong noise.
How do I turn it off? I can't find anything in the menus or in the manual, and it's driving me nuts
Oddmanout
121
48
I know you can adjust it with Carista, not sure about on the menu as standard.
I thought the default if this is activated was 75mph though not 69!
dannytremendous
51
16
Mine did it at 85 it was in the menus. Think it’s under driver assistance or something like that and then speed warning
Deleted member 103408
On my car there are three warning.
Winter Tyre warning - this you can set yourself in one of the menu's
Speed warning - again this can be changed in one of the menus
Then there is the onboard one that is fixed at 75
furtive
7
9
Thanks all. Found it eventually.
It's not in any of the settings on the infotainment screen (my winter tyre warning was not on). It's accessed via the driving data using the right-hand thumbwheel on the steering wheel.
Reactions: Oddmanout
Yern
628
311
My last car (Nissan) had speed limiter which I always used and certainly if driving in an unfamiliar area. It wouldn't be difficult for Seat to have added the feature but they haven't so I have speed warning set to 32mph. It can be fiddly to set anything outside of the 'standard' 5mph range (i.e. 30mph/35mph) via the wheel controller.
