Right so Scarlett was at the
garage again yesterday to get the alignment and geometry sorted out which ended up mostly fine. Slightly out of spec still at the right rear but with little options back there for adjustment it would cost a few hundred at least to put right so left that as it is. Balanced out the negative camber at the front a bit and got the toe and caster fixed so the steering wheel is finally straight. That was weird driving to work this morning, gotten so used to the wheel being a few degrees off I kept finding myself wanting to correct it!
Anway, to recap, this was the state of play before:
And here's how it looks after:
I've only done my daily morning crawl across town to work so far since getting it back (the
garage collected and dropped off my car, that's what I call
service!) so can't say much for benefits so far other than the wheel being straight, altho the steering feels reassuringly weighty again like it hadn't since getting the front ARB fitted, so I suspect the tyres are making better contact with the road again.
I also had them change a dead post-cat lambda sensor and a dying thermostat so I'll get it out for a decent thrash this weekend with some logging on to keep an eye on temps and fuelling and see how/if all these things have improved matters.
Anyone in the Aberdeenshire area looking for wheel alignment, go look up Clark Motorsport in Kintore - top blokes, top
service and good prices too
