A couple of codes I cant identify... help please
Jampot1979
Hi, I have a 2006 Leon FR TDI 170.
Engine light came on.
Two codes have come up......
01650
04723
Can someone please tell me what they are?
Many thanks
James
My1stIbi
What tool did you use to read these codes? I.e. are they generic OBD2 or VAG-COM error codes?
Did you check your fusebox?
Jampot1979
Hi, I used the handheld U281 UIFTECH Code Reader. Purchased off ebay!
My1stIbi
And TFM wasn't helpful I guess (from their product page): "identifying, locating and checking out trouble causes with attached user's manual".
Ross-Tech has a WiKi which gives some info on the 1650 code. Couldn't find anything on 4723 though.
(unfortunately I'm to much of a noob to give you the links, 9 posts to go)
spud31
Rail Zip User
Jul 14, 2011
407
p1650 Data Bus Powertrain Missing message from Instrument Panel ECU
p4723 issue with injectors
get this car to a dealer quick sounds like its got pd170 injector faliure
Jampot1979
Thing is we had all 4 injectors replaced plus loom only a month ago by SEAT Main dealer!
hmmmm!
Jampot1979
The code reader I have is the U281 hand-held Reader.
Plugged it in again today and this time had these 3 codes logged:
01650
01652
05491
The manual which comes with the code reader doesnt show these codes... aagghh!
My1stIbi
Still difficult to find the right description if it not sure which error code is displayed. As per RT wiki:
"17058/P0674/001652 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug Wiring faulty
Glow Plug faulty
Possible Solutions
Check Glow Plug Wiring
Check Glow Plug "
1650 is cyl. 2 glow plug.
Couldn't find anything on 5491...
But as per gerritspeek.nl 1652 could also mean this: 01652: Airbag cut-off switch, driver's side
And planetvag.com gives this for 1652: Please check DTC Memory of transmission ECU
Does the manual give any info on what type of codes are displayed?
