Hi guys,
Got in my car today, to go get my brother from his mates.
The car was still warm, as I had only just got back from Uni in Bristol, so had been on the M-way for a good 40 mins.
Went to boot it on the dual carriageway, which is up a fairly steep incline. Got to 60, in third, just before I went to change to fourth, all power went.
This carried on all the way to get my brother, I stuck my head out the window, and couldn't hear the usual turbo spool, and this is where the power went flat. :cry:
Switched off engine, turned back on 5 seconds later, an it was fine.
Is this a warning sign of things to come??
Just hit 106k today, service due in 1800 miles....
Any advice is appreciated.
Oh, its a 110 TDi SE 51' plate.
Cheers,
Ben
from what i understand there was no warnign light..
it just seemed to go into a type of limp mode!?
you will need to vag com it, there are alot of things it could be. but feel free to check for loose, cracked / damaged pipes under the bonnet.
Yeh, no warning lights at all. It then worked fine when restarted... which was odd.
I have changed the MAF in the time I had it.
