Well Arun.. You've put in the good work, and it has shown!! Your car is a credit to you bro! Get up to mancs for a p0rn photoshoot :p
haha you're a joker, thanks man :love:
i must have missed that post,sounds like another product i need to buy then not heard of it before.
Awesome stuff, it's not cheap though!
BOOM
This is all you're getting till UD ;)
I've tried looking for the brand, but without success....so have to ask....what make/brand of coilovers did you fit to Laura?
JOM's dude :)
:love:
Right, thought I'd update on a few things that I've been doing!
Firstly, got some rear camber!
Hub off
Washers in
And in the calipers to bring them level with the discs
End Result, no more scrubbing at all! Though I think it might need a couple more mil spacing, but nothing major!
Next, cleaned out the inner arches, rolled the arches flat and pulled them slightly, then fitted new arch liners
Before
Sprayed with APC, then worked in with a brush
After
Then went on to roll the arches
How it's sitting atm, got some 10mm H&R spacers on order for the fronts so should get it sitting well!
Thanks for looking
Like the ingenuity of the washer spacing although I'm not sure I'd have faith in that as a permanent set up!
Can't really see much to go wrong, bolts are all tight enough ;)
Plus I had a choice of metal washers, or nylon shims....Don't think I'd want to use plastic lol
Got my tracking done today...both fronts were facing out by about 1-2 degrees lol, no wonder I only got 400 miles out of the tank last fill up!!
Babes! I'm loving the OCDness. Are you sure that's safe mate? Granted, you're only losing like a mil? of bolt length... but still. Spaced on the front and that should be sitting very nicely indeed! Good work on the arches babes :)
Thought you might like it :love:
Yeah it's pretty safe, i've heard of people running 2-3 washers, or wider shims, and they seem to run with no problems! Mine is only 1 washer, and there's still 10-15mm+ worth of bolt threads hold the hubs and calipers on :)
Your car is ridiculously low fella! My mate didn't believe me when I said it was on coilovers, he was sure it had to be on air :D
:happy:
Quite a few people said that too me, made my day haha!
Good shot of the rear camber! I like.
Cheers dude [B)]
After seeing a lot of the cars at UD, I now want another set of wheels :blink:
