F2 Ed
now has VAG com
Nov 5, 2006
919
www.superlite-wheels.com
It is possible to program the current settings you want for the counters. This used if the speedometer console is replaced or if you want to set your intervals to a shorter value than the factory. For example, you can set the computer to display OEL after only 3000 miles.
1. Turn on the ignition (do not start the car)
2. Depress the trip-reset button on the odometer.
Also depress the button to set the MINUTES of the digital clock (lower one).
3. The LCD display should read "OEL 1,S", where the S indicates SET.
4. Using the trip-reset button, you can call up the following counter banks
for the service intervals in sequence:
OEL 1,S- distance counter for oil change (ie 7500 miles normally)
OEL 2,S - time counter for oil change (ie 12 months)
IN 01,S - time counter for yearly service interval (ie 12 months)
IN 02,S - distance counter for special service (ie 15,000 miles )
5. Using the button for setting the MINUTES on the digital clock (lower one), you can display the value of the counter. Repeated pressing of the button will select a subsequent lower value of the counter and at the lowest level, it will reset to the highest level and begin to decrease again.The step sizes are blocks of miles (500 miles, I think) and months (the time setting for the yearly service is a bit strange as I think it can be set to 1,2,3,4,5 or 6.
Maybe it counts in 2 month blocks? Does anyone know?).
6. Once you have set each counter to the value you want, turn off the ignition.
7. Work is done.
Well i didn't know that:happy:
