AFS Error
PaulusB
172
38
Hello I got the following error.
I have read many topics about this problem I replaced the front levelling sensor and checked the wiring. The error stayed away for one day.
This fault code only appears with heavy rain during 2 days. Short period off rain no problems. This was the same issue with the old sensor. I checked the rubber inside the wheel weld for the wire and this sits ok.
Does somebody know where to look? The light on the dash and the ping is driving me crazy.
In the afs module it self?
The ballast under the headlight have no fault code and when it dry the do there upside dance on start.
Verstuurd vanaf mijn SM-G930F met Tapatalk
PaulusB
172
38
I did a scan with vcds
Software Coding: 2555909
Work Shop Code: WSC 06403 785 00200
Additional Info: 7L6941329A AFS-Lst.-Modul l 0002
7L6941329A AFS-Lst.-Modul r 0002
VCID: 326A2254AD2F60D64C-8066
Fault Codes have been Erased
2 Faults Found:
00496 - Sensor for Vehicle Leveling; Front
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 146
Mileage: 188552 km
Time Indication: 0
Date: 2000.00.00
Time: 20:33:56
Freeze Frame:
Voltage: 11.93 V
Speed: 0.0 km/h
ABS 1
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Than I looked at al signals and indeed front sensor no signal
When u enter the security code and try to perform a basis setting alignment I fails because its missing the front sensor signal. So group 001 is missing.
Can somebody tell me where I can find the controller in the car with code 5M0907357A (2007) I ordered a used revision one with number 5M0907357C (2010) is this part interchangeable? When I coded it.
PaulusB
172
38
Zo fixed the problem I bought I used 2010 afs module with revision letter C from a mark 6 golf.
I swapped it and swapped the original coding then did a basic headlight adjustment in vcds and boom all the errors where gone.
I opened the old but cannot see anything wrong on the soldering. Maybe its in the chip.
Whatever its fixed for 15 euro.
