aftermarket limiter
smiler220
rollin at 220 want more!
Oct 16, 2006
92
Bournemouth
Has anyone fitted an aftermarket limiter to a mk3 ibiza. I want to fit one but unsure it would be worth it. I want to restrict to 5.5k as very little boost after this. Hit me with your thoughts!!!! Oh also hoping for a few pops and bangs when on limit.........If its a goer which type and manufactuer is the best.
jamesroobotom
cupra mk3
Jan 7, 2007
103
STOURBRIDGE
tell me if i'm wrong, but would you not be restricting your power........ i mean if you had a bigger turbo than standard it would drop off later than 5.5rpm wouldn't it?:confused:
smiler220
Oct 16, 2006
92
Bournemouth
There is verylittle power over 5500k mine is off boost way before then so all your doing is reving the **** out of the engine i thought the idea is to stay on the boost , childish it may sound i love the pop and crackle you get when hitting the limiter.
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
There may be little power after 5.5k but there is power there (log your airflow) also there is still speed in the form of revs, its easy to think your wasting your time after 5.5k because of the boost drop off but i bet you'd set quicker quater mile times if you shifted nearer 6.5k than if you did at 5.5k.
smiler220
Oct 16, 2006
92
Bournemouth
Yeah looked at that limiter but it seems to overfuel and produce flames!!! not really a good idea with a cat. Do you think it would fit the beeza!!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
omex ?
shiftlight to warn you and/or limiter if you need it
they do a full throttle gearshift and launch control too
smiler220
Oct 16, 2006
92
Bournemouth
Cheers Flapper going to look into that one. Do you think it would be ok to fit this to the beeza, i know how sensitive they are with fault codes.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
have seen one fitted before to a vag 20vt but a quick call will settle any Q's
i'm biased as they are currently rebuilding a custom sequential light for me after i melted it :)
and i supply parts to em too ;) if it is any good let me know might be able to get a deal for ya ?
smiler220
Oct 16, 2006
92
Bournemouth
Cheers Flapper leave it wit me going to do a little more investigating but i will be intouch i like the sound of a deal!!!
