AHHHH!!! No power to anything!!
buff2ruff
today i tought that it was a nice day to fix my electric window :) after a 45 min mission tyring to remove the door card i found a guide here, then i dismantled the door and tried to put the window back in its runner when the wire that controls the up/down motion of the window come out of its reel:cry: , so i had to remove the elec window motor[:@] , any way as i was inbetween doing things i realised that there was a TICKING noise coming from the dash board and all the LCD displays (milage, trip counter & Time) were flashing RAMDOMLY so i tried to fire the LITTLE TART up and there was nothing:censored: :censored: :censored: just the fisrt click of the starter motor!
so can someone please:help: me as the car now has no power and the rear window is down!!!:wtf:
as you may have relised i forgot to disconnect the power!!:redface:
buff2ruff
ibiza_95 said:
is the battery dead? it sounds like theres no power in the battery for one reason or another
NO it dont seem to be its sparking as i connect it up again and there is the EPC, ESP, starting motor, and the battery light is dim.
then when i turn it nothing stays on!!
not even the stereo works
ibiza_95
1.8T MK2 Conversion
check the earth point at the battery maybe? thats the kind of sign i gives when a battery is flat. as in theres a bit f power there... enough to light the lights on the dash, but when you start it over, the drain to the startr motor is too much and thus turns everyting off
