Air Bag Light - No Fault Code
danwade333
12
Stoke
Hi Everyone,
I have an airbag light on my dashboard which I think popped up when I removed the glove box to route a dashcam power cable.
It was put back together and all was fine then the airbag light popped up. I've scanned with a bluetooth scanner and cleared all codes but none were found. I have also scanned with an autel scanner which can't find any codes. I have tried clearing everything but nothing has changed? Anyone experienced this?
I have re taken the dash out and plugged everything back in again and nothing has changed.
Car is a 2013 ibiza toca 1.4
300bhpdaily
1,246
568
Hi is there anyway you’ve turned off the air bag switch in the glove box if yours has one when you took it out? Also sometimes when air bags are unplugged and the connectors aren’t properly clicked back in they break the circuit and once the air bag lights on it won’t turn off without the proper machine to reset it. I did it when I had my seats out.
