xwardos
Lord Cumalot
Jul 21, 2011
16
Malta
If i wanted to replace/replenish/refill the Aircon Gas of the car...from where do i do this and what do i have to do?
Edward
Contact someone that specialises in it. Most garage have the correct machinery. It is a refrigerant so you can get into a lot of trouble for just venting it out to the atmosphere.
The correct machinery pumps in the correct volume at the correct pressure. This is not a task you can DIY.
The rules might be more lenient in Malta, so perhaps you can still buy the cans of gas and oil which were available here not long ago. I still wouldn't recommend venting and replacing, but topping up should be OK.
You still need to know how much is in there and how much you put in. Having too much or too little pressure/volume can cause bad performance.
