This is my problem, is a faulty sensor the obvious fault that would cause these symptoms? Or would an air leak cause a working sensor to throw up fault codes? For all i know, the sensor is just doing it's job. £130 is a lot of money for a part that i may not need, so i hope you can see where I'm coming from.
Hi mate, that first code P0402 is for the EGR http://wiki.ross-tech.com/wiki/index.php/16786/P0402/001026
If that has failed or stuck open, then that will mess the mixture up, although your codes appear to be for the heating part of the lambda sensor/circuit http://wiki.ross-tech.com/wiki/index.php/16414/P0030/000048
I'd be checking what the EGR fault is, and also checking for damage or corrosion to the electrical connections to the lambda, before i splashed out on a new sensor.
Edit if you can get the proper 5 digit Vag fault codes, that will probably show a lot more than just the generic OBD2 P0030 codes
