I've had an airbag warning light on for a few months. Now I'm able to do something about it. I've had a good search of the forum and I am none the wiser as to how to scan and reset the code (I'm aware this is probably noddy to many of you but I've never had cause to use a reader before). I have seen specialist airbag reset equipment on the internet (expensive) and I've seen posts that say to use a standard code reader with OBD2 cable to scan and vagcom to reset. Is it as simple as being able to use a OBD2 cable and compatible reader to scan? Can I download VCDS Lite and use it to reset the fault? Is it the case that VCDS is the only way to reset the fault after it is fixed? Or can I do everything with a standard reader and OBD2 cable?
I'm guessing that a wet floor/pot hole was to blame and that the cable under the seat has come loose. I've since sorted out the door seals.
