Aircon Compressor not engaging
Nov 19, 2023
Hi guys,
Previous issue - AC would cut out while driving
Issue resolved by replacing a leaking condenser.
New issue - ac compressor doesn't engage and fans don't come on.
After I switch off for a few minutes and switch on again, the compressor comes on with fans.
Once it's on, it's ice.
Anyone had this issue before or can guide me along?
I am not sure if my compressor is on its way out
May 29, 2024
Check if fuse box on top of battery has good connections. One of the 3 green fuses to the right control it, and the fuse box is prone to failing.
Could also go to the plug that connects to the condenser and see if its getting 12v when you turn it on, or even feeding the connector 12v directly an listening if its engaging
