alarm fuse location?
dru
Afraid you may have to bite the bullet and get the codes read to determine the problem - as a temp fix try this - if you lean in through a rear door and press the lock button on the centre console and then close the rear door this should lock your car without the alarm.
It should think you are inside so won't ARM the alarm.
This may get you through until you find the problem, but looks again it may be the door module - best of luck, dru
Dubslag
Barrythefrash
Dec 21, 2011
21
Mansfield
This should be a recall, my cars had both locks and door modules before when it was about a year old. I've found a bloke breaking the same spec car so I'm going to see what he wants for the big black jobber in the passenger door as this seems to be the part that keeps causing all the door/alarm faults .
I might even ring seat and see what they say cos I can't see why I should keep paying out for crap parts
