bmwww
42
Hi,where is alarm horn . My horn not working ! I just don't know where is :(
According to ElsaWin, it's behind the front of the front O/S wheel arch liner. The liner doesn't have to be removed completely, just unscrew the front of it and bend it back. The cover for the horn is riveted to the body and has to be drilled.
If you have access to VCDS, the horn can be checked.
The alarm horn -H12- may be verified using the switch diagnosis of the comfort system control unit -J393.
Not a good diagram but gives some idea of what it's like.
[URL=http://s192.photobucket.com/user/timsawf/media/AlarmHorn_zps75184066.png.html][/URL]
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C0009C2D000505484B080004CC
Shop #: WSC 06441 785 00200
VCID: 79F56EE760D952CB44D
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
:banned:
where is this location ... I do not understand :(
It in the drivers front wheel arch, remove the plastic cover and you'll find it at the back behind the side repeater.
Is it possible my car don't have alarm horn ! What is this fault found ?
Someone may have removed it but seeing as though your CCM has thrown that fault I suspect your car came out of the factory with one installed.
The CCM will flag that fault if the alarm horn (which is completely different to your normal horn) looses its voltage, this is usually because the internal battery in the horn has failed.
CCM ? I don't know good english ! Please easy word ! My car have alarm horn .. yes ot not ? :D
Thanks ! I check morning alarm horn ..... left side ? right side ? My driver side is left !
I want to ask ... plastic beneath the windscreen glued it? Because I sweat glass as drive air and put it out then! I think this is due to retention of moisture! My filter is new!
