chudspeed20vt
Hi there,
ive had it about a month now, i replaced the battery i knew i needed to do the throttle body adaptation which i did, it the came up with lower limit not reached fault code, i removed tb and cleaned it after that it came up with tb malfuntion, control limit exceeded, fault in basic settings and throttle position sensor malfuntion, car idled allover from 1000 - 1500 and when on full throttle it intermitantly died lift off slighty it was fine again.
So i order and fitted a new throttle body and guess what still puts 2 codes up 1545 and 1565, it does idle better and accelerates better but still dies on full throttle, after it dies it puts up the fault code for control limit exceeded.
Im a mechanic by trade but havnt had much vag experience, this is baffeling me now so if anyone could help id be very grateful
its a mk1 alhambra 20vt engine code ajh year 99 t reg
thanks richard
thanks richard
