truffler
Hi all first time posting so bear with me please, This site has already helped me twice with 2 problems, alternator pulley and thermostat both faulty but now sorted. I need your help with a new set of problems
No 1 Can anybody send me a picture or a link for the set up of the front top suspension mount my hole shock/spring assembley moves ALOT !! when jacked up and you shake the wheel top to bottom (other side is solid). Been reading the other posts but cant figure out what is keeping the spring compressed is it the top mount or is there something else under the top mount doing this?
No2 Temp guage is erratic very slow to go up although the heaters are worm then it shoots up 10-20 degrees then it drops back down then goes back up as if it is waving good morning to you. It does get up to 90 degress in the end and stays there happy till the engine is switched off
