JLWLS87 Fancy taking on the new beastly Formentor VZ5 at Santa Pod?! Find out more here .
Hey JLWLS87
We're looking for reviews of your local CUPRA or SEAT Dealership - it's quick and easy to do: Leave a review now
New member here Altea question for a friend
- Thread starterJLWLS87
- Start dateSunday at 22:11
- TagsNone
Unwatch
JLWLS87
Hi I own a leon sport tdi pd 140 bkd.
Asking this question for a friend.
He has a 58 plate altea same engine and is having problems with rear passenger door.
I've had the problem with the door locks sticking on mine and have drilled the hole in the mechanism and sprayed wd 40 In on 3 of my door locks worked perfectly.
The problem he has is that the child lock was activated and it seems like the mechanism has failed as drilling the mechanism an spraying wd 40 in doesn't work. But it can't be worked in as door will not open from outside due to mechanism being seized and door won't open from inside as child lock is activated has anyone had this problem?
Any help would be appreciated as This is the only reason he has given up on the car he has 2 children in the back and has to put them both in from the drivers side rear which is far from ideal on the school run.
Thanks in advance Joel
