Jan 8, 2026
Hi , I’m just posting for a little help . I have recently bought a 2004 Leon cupra , first ever vag car I’ve owned . The front passenger door locks from the inside of the car . But when I try to lock the car from the exterior with the fob and key the passenger door is still open but sets of the alarm . Is this a common issue and any fixes
Hi Kdog12,
This is a common issue on our cars and usually means the door lock module needs replacing. You can get eBay units for a decent price and some last years while others are a lottery!! Even the oem units fail over time (I wish there was someone who could repair these)
Loads of videos online of how to replace module and not too bad if you’re handy with tools. Don’t use silicone to reseal the door plate, use Butyl Tape
It's a pretty involved job, but once you know how to do it, it's much easier if you ever have to do it again. Fronts are easier than the rears as the window carrier bolts in for the front, but it's a push fit plug for the rears, which is easy when you know how, but frustrating when you don't. I took the glass out completely when I did my driver's side one.
I don't have the sizes to hand, but you'll need Torx bits to get the door handle out, and a triple square (12mm?) to get the lock itself out.
I'd definitely recommend doing some cleaning and regreasing 'while you're in there' - especially the exterior handle - the screw that holds the lock barrel (and the blanking plate on the passenger side) corrodes and seizes. Just give it a light sand to remove the rust and then some grease. Once you use the butyl to seal the panel back in place, it's a sticky mess if you have to remove it again, so everything else that looks like it needs doing, do it.
Can't stress enough, if it's on the original seals, scrape them off, clean the surface with IPA and make sure the butyl is even and there are no gaps. We all know the pain of wet carpets and steamed up windscreens if it's not perfect.
I've not had any issues with eBay locks myself - just don't buy the cheapest one you find. Some come with weather foam around the bit that's open to the elements - given how rusty these bits can get, you might even want to add your own. Some people strip the lock and grease some of the components before installation, but things can go wrong if you don't put it back together properly.
It's all pretty intuitive though and it's hard to go wrong - just don't rush. Everything should come apart without forcing. It's maybe a 1-2hr job.
Reactions: mty12345
As others have said. 99% of door lock issues can be resolved by replacing the module. I'd recommend getting the Ridex branded one from autodoc, as the quality of the ebay and amazon ones seems to have gone right down. I got royally screwed by an ebay module recently
Step by step video here of how to replace it.
As the lads said above, install butyl rubber on your door panel while replacing it. Guide to the type and where to install it here
Febi do a good alternative and look exactly the same as Vw but a bit more expensive than the copy's but they are jumping on the 3rd party supplying as they seen the market
